Aeroforce gauge on 2013 Boss - Does it display actual Oil temp or Oil Pressure
2013 here. I added the fuel pressure sender to give real time data on my Aeroforce for my 2013. There's a thread you can find on the parts/install process for the sensor.
HackBoss302 said:
Anyone using an Aeroforce gauge on a 2013 Boss? My question is will the Aeroforce gauge read the actual oil temp or pressure without having to install aftermarket sensors?
Thanks Chris
Not sure if the aeroforce will read the oil temperature through the obd2 port. You are able to read the oil temp through the stock gauge right? Oil pressure would require a sensor. I did it on my 2012 last year.
https://trackmustangsonline.com/index.php?topic=811.msg18297#msg18297
