AiM Fuel Pump Sensor
Many modern aftermarket pressure senders work by outputting a range of 0.5v - 4.5v instead of a resistance, and you can split those with some caveats. But OEM fuel level senders are simple variable resistors.
Understood on how this would be a problem with trying to split the sender with two gauges that are supplying the power. But the Aim unit can act as a passive listener and just read the resistance. It’ll work.
I wanted to post a follow-up and publicly thank Kevin. He took a good amount of time out of his week to go back and forth with me on my AiM setup and significant progress was made. While not every incorrect AiM channel was fixed, he was able to find a fuel level channel and that was exactly what I was seeking when I started this thread. See video below. I'm not certain how he was able to do it (beyond my tech understanding) but very grateful. Thank you Kevin for your time, I greatly appreciate your efforts.
Max Fuel (off a bit but way better than being blind)
Kevin so you have a protocol to track fuel flow by lbs/hr? That is what I am looking for too, just for the S550 GT350 protocol
Uncertain, but that was not available in the S197 channels we tried to activate. Kevin was able to find the fuel/tank level percent channel that mirrored the OE fuel gauge, but not the fuel flow lbs/hr in my setup
