- 675
- 253
This is where I bought my KW V3s from, significantly cheaper than anywhere else I found.
http://www.jegs.com/i/KW+Suspension/601/35230045/10002/-1
Champale said:This is where I bought my KW V3s from, significantly cheaper than anywhere else I found.
Grant 302 said:Not sure where you'd get the AST now. Vorshlag is carrying 'MCS' branded components now. Might just be a brand name change?
Grant 302 said:Why not the Spohn Del-Sphere panhard too?..
modernbeat said:We tried one of those, with high hopes too. It turned out to be extremely noisy. Tried their upper arm also. Same story.
ArizonaBOSS said:http://www.summitracing.com/parts/rsp-403151?seid=srese1&gclid=CLTi6P7h-r0CFZWSfgodHJsAfw
That's what I run, although I contacted KW (Roush's manufacturer) and got a softer rear spring set.
Supposedly the fronts are 515lbs/in (not verified) and the rears are 400lbs/in (verified by KW). I put in a 230#/in rear spring set for better corner exit traction.
It's comfortable enough to drive on the street even with the 400# rear springs; I drove it on the street like that for a couple months.
You might want to call Summit and make sure you can actually get that set, I've seen a lot of people say they are just SKUs and not available.
Next best option, IMO would be an AST 4100 set. I don't have any experience with them, however.
Arizona, are your Roush KW's having a front conical spring (small at the base and OEM spring diameter at the top mount)?ArizonaBOSS said:Roush has them custom-valved, but the equivalent would be something like a KW V2...single-adjustable rebound w/ camber plates.
cosm3os said:Just noticed the Spec Iron shocks are $2400. Dunno anything about them. http://www.hancheyvehicletech.com/product/HVT-F1001-SI.html
These look interesting. Who makes the dampers in these? Is it HVT? I see they also offer JRi's as well. I'm still waiting to here from CorteX on their new single adjustable JRi's that should come in around $3K.cosm3os said:Just noticed the Spec Iron shocks are $2400. Dunno anything about them. http://www.hancheyvehicletech.com/product/HVT-F1001-SI.html
