S197 Best track & road brakes
Omaha NE
Looking for suggestions on brakes. Working towards tracking the car but for now it’s a weekend driver on nice days. Stock Gen 1 coyote with Brembro’s.
What should I upgrade first? What’s the best pad for my application?
Dave_W
683
846
What's on the car now, and when was the last time the brake fluid was changed? Also, are you new to track days or have you run them before in something else?
You want to use at least a good DOT 4 brake fluid, or a DOT 5.1, never DOT 5. If you don't know what's in the car now, or if it's older than a year, flush with new. If it's good and fresh, you can just do a bleed before each track day, and maybe after as well. Note that "flush" is different than "bleed" - bleeding is just removing any air bubbles at the caliper; flushing is replacing all the fluid in the entire system.
For pads, there are several brands that folks here like, each with different compounds. The compound determines the temperature window the brake pad is "happy" in. "Street" pads will work from cold but will disintegrate at temps that an experienced driver can create on track. "Race" pads like to be warm/hot to work and will hold up under extreme heat, but will squeal like a stuck pig and destroy brake rotors when cold.
There are some companies that sell "street/track" pads that will probably work for someone new to track days that is not using the brakes that hard. Once you get more confidence and use the brakes harder, you'll start needing a set of pads for the street and another set for the track. Some pad manufacturers (e.g., G-Loc) have street & race compounds that are compatible with each other, so you don't need to change the rotor. Other pads may need to have their own rotor that's been bedded-in with that compound.
Note that the traction control system on the Mustang likes to apply rear brake, and can end up overheating the rear pads, and/or melting axle seals from rotor heat. If you're still building confidence on track, at least set the traction control to sport mode (car on, press brake pedal, push TC button?). Ideally, you want to turn it off completely (car on, press brake pedal, hold TC button down for 10 seconds?).
If you look at the Supporting Vendors scroll near the bottom of each forum page, you'll notice Optimum Performance (aka OP Mustang) and KNS Brakes, as well as EBC and Cobalt brake pads. Please support them if you can. OPM and KNS are both very knowledgable on Mustangs and can help put together a package that fits your current needs and has some room to grow.
Some tracks are harder on brakes than others; @Bill Pemberton will have a better idea of track-specific brake needs in your area.
Other than brakes, the number one modification I'd recommend is camber plates (Vorshlag, Maximum Motosports, Steeda, Ground Control). They will keep you from grinding off the outside shoulder of your tires, or at least reduce it. And then tires that have decent grip but can take a full session without getting greasy. For novices, seat time is the most important thing, so you want a car that is durable enough to be driven hard for an entire session, for all the sessions in a track day, and doesn't change how it responds to the same driver inputs through a session. You'll learn fastest if your car is reliable and repeatable.
I always recommend making upgrades in this order -
Make it safe.
Make it stop.
Make it turn.
Make it fast.
And remember to have fun.
Omaha NE
Make it safe.
Make it stop.
Make it turn.
Make it fast.
Thank you, all good information! It’s a low mileage 5.0 that I’m still building confidence in so in the stage of making it safe and reliable. New to track days so need seat time more than anything.
I’ll talk with those vendors and will start with a bleed and street/track pads while keeping the traction control in sport mode for now. I’ll also look into camber plates don’t want to shred through tires. I have Nitto nt05 on now. Will those make it through a season? Once I get it set up for track days what’s a novice budget look like?
Pads, pads, pads! I have used PFC and G-Loc pads track pads and they both felt like someone dropped anchor compared to anything resembling a street pad. $300 seems crazy until you've gone a few laps and then it seems like the best investment you could make. If you stick with the same brand for street duty then you can usually just swap the pads on the same rotors. I'd also recommend Castrol SRF fluid. While it's also very expensive compared to most typical part store stuff it's the most capable and forgiving street/track fluid I've found.
Also agree on the camber/caster plates as it will save your tires and help with mid-corner grip.
255
OP, swapping the front pads is super easy with those Brembos and real track pads are just so much better -- both in terms of extra bite and fade resistance. Get a separate set of race pads and swap for track days. You aren't saving anything by burning up street pads on track and more importantly their performance sucks. Just as track pads suck on the street.
At least for HPDE you can cheat and use a dual-purpose pad in the rear. Those take more time to swap and are doing a lot less work, obviously.
