Hi everyone,
I'm in the process of installing the BMR Handling Springs for my '18 GT350. I worked on the rear first and installed by lowering the subframe one side at a time. For those that have installed these, the instructions mention trimming the front and rear bump stops, but there are no steps outlining how to handle the rears - has anyone done this? The Magneride shocks make me a bit nervous with the wiring coming out of the top of the shock. I guess I'm a little confused, because the installation videos I've seen for the Ford Performance springs mention nothing about trimming the bump stops and that kit is a bigger drop.
I also discovered after-the-fact that a number of bolts are one-time use. Does everyone replace the subframe, stabilizer link, and shock bolts/nuts?
I will be attacking the front springs once I get back from vacation and installing my Vorshlag caster/camber plates at the same time.
Thanks,
Brian
Thanks,
Brian
