Boss 302 R/S Upper Control Arms
My understanding is that the Boss race cars are using a modified rear upper control arm (possibly by Multimatic).
Does anyone have any more info on this? Any ideas on where to get one (Rehagen, Capaldi, or direct from Multimatic)?
This part can only be purchased from Multimatic directly. Call them up a t905 470 9149 and ask for Sean Mason. Be prepared to pay a VERY pretty penny for this part.
Can you confirm the correct torque spec for the big bolt in the backseat area? I've heard references to 350 ft/lbs. but can't seem to find that in the Ford manual, nor understand how you would get that much torque on it.
175 Nm or 129 lb-ft
cloud9 said:
Thanks. That's what I saw in the manual too. Not sure where this 350 ft/lbs is coming from.
Probably from here.
https://trackmustangsonline.com/index.php?topic=4029.0;topicseen
VTBoss302 said:
Update:
The bits finally arrived from Multimatic.
I took a few pics in case anyone is interested:
New to the forums. This is interesting because I was always under the impression that the R and S cars used the factory upper control arm in the rear. Did they change this at some point? It looks like the rubber bushing in the chassis-end was replaced with a solid piece of metal (steel)? I always thought the 3rd-link/upper rear arm required a lot of articulation?
If you take a closer look at the last picture you will see that there is a spherical bearing in there.
Found a picture of the control arm on a 2013 302S
What made you go with the expensive Multimatice control arm and not something like a Spohn Del-Spere or UMI Roto-Joint?
It's a little pricey, to be sure.
I guess I was willing to pay more for the genuine race car part.
I haven't installed it yet and, to be honest, I'm not even sure if I will.
I would probably be willing to sell it at a deep discount in case anyone's interested. ;)
that is a steep price. My Steeda Adjustable UCA and Heavy duty bracket came in for about half that price and looks about 5 times beefier.
Just curious what makes it so special other than its "on a factory race car"?
NFSBOSS said:
I believe the Grand Am cars are required to use the stock UCA so Multimatic just modifies it so the R's meet spec. No doubt you are paying for skilled labor and not for materials.
ah ok that makes sense. it looks like they took a factory arm and pressed out the bushing and put in that.
