Boss 302S new CJ motor test
That sounds awesome. Good luck this season.
Thanks guys , first race is at Portland International May 2, 3 , looking forward to the additional power on the long front straight.
BossMoss said:
That does sound absolutely amazing! Care to share your exhaust setup?
I am running American racing 1 7/8 inch long tubes with a x-pipe and a custom 3 inch system with flow master mufflers that are in the stock fuel tank location not at the rear of the car
8,733
2,735
bbrgt said:
That's actually the dyno limiting the RPM
Wow. Didn't know that was possible. I've only used dynojets before, though. Cool!
Thanks for the update. Your Boss sounds amazing!
On the Dynapack you set the start and finish RPM and length of the run and it limits the pull to the upper RPM value. The only drawback is you have to set the finish RPM slightly below the rev limiter on the car you have on the dyno or the run values do not record correctly .
