Does any body know of a way to get the front fenders of a standard 2017 GT wider to match up with the rear so I can run a square 305 set up with out using tons of camber?
Im primarily looking for modest stick on or bolt on flares that look some what natural that will cover the tires with out tons of poke past the bumper.
I know youre able to get ½" wider fenders from anderson and similar companies, but that still leaves alot sticking out past the bumper section of the wheel well.
The alternative is buying a whole shelby gt350 front end which I unfortunately cant justify the price to do that and I really dont like the whole making a car look like the top trim level when its not thing. Like slapping an m3 badge and quad exhaust tips on a 325.
Current wheel and tire set up is 19" steeda trident wheels 10" wide up front and 11" out back and id like to run the 11" wide rims up front as well. They use a +53mm offset.
If anyone know of any solutions or ideas I would be very appreciative. Thank you very much in advance.
