@21CarProductions @NJS58 Racing @NJS58 Eurosport
Ford system is a bit more sophisticated than the GM systems, especially the earlier Gen Camaros and Corvettes. But the Ford system has g level limits where when the calculations on brake pressure, speed and deceleration rates go off the tables you get the brick pedal. It is real and Sandro certainly is exceeding the limits. As long as the car isn't rapidly slowing one or two tires more quickly than the others the system plays nice. But once hard ABS is called for it can get dicey. Or icy. I have found that a firm progressive pressure build vs a "spike" of the pedal will keep me out of ice mode at the typical corners it happens, Turn 1 VIR, Turn 7 at Sebring, Bus Stop at Watkins, and less frequently the Bus Stop at Daytona. If you can do it get the Bosch. It is a very adjustable system that can be tailored to specific tire and track conditions. Since you don't care about the Advance Track programming, disabling it and the ABS through tuning is not an issue. Can't wait to see the upgrades, it won't make the brake peak performance that much better but the modulation, consistency and lack of worrying about ice mode will be gone.Found the article about stock style abs I had read. Short version, it assumes you are on ice until it determines otherwise everytime you hit abs. So upgrading the abs system first then allows what you have to work better straight away. Then you can address wear rates etc.
Apex Automotor | Quick definition of "**Ice Mode**" in ABS, as this can be really scary or even cause an incident when it happens on track | Facebook
Quick definition of "**Ice Mode**" in ABS, as this can be really scary or even cause an incident when it happens on track. If you've experienced it, you'd know. *I posted this on another page, but...www.facebook.com
