so I did an oil change at 1000miles (as all of you should do), and I noticed the engine was a little bit quieter and smoother, which is a good thing. so I think I am going to stick with the AMSOIL brand for now.
Also did a tranny fluid change, on a tech car it was pretty easy, drain bolt at the center bottom, fill hole is right on top of it on the driver side. used about 2.4qt. I didn't go with Ford's OEM tranny fluid as I was not convince it is full sync, I used PENNZOIL PLATINUM LV MULTI-VEHICLE ATF which is full sync and meets the Ford's specs to a T. it has the same color and texture as the OEM fluid and it was not expensive at all.
also, i noticed, if you hold the clutch for 5s before you start the car, you can hear the fuel pump being primed, and it in turns caused a less violent and loud cold start, may consider doing that if you start the car early in the morning so you don't wake up the neighbors.
