- Thread starter
- #381
Yep. The mounts for the fan were different but it had the tank at the bottom. They said it was a three core with the passage tubes being smaller.
I got it installed today.........took way too long but I wrote it up in this thread:NFSBOSS said:That's not bad. With my stock setup and CJ grille i'm regularly in the 215-220 in similar weather conditions around sea level. There's also some elevation at Chuckwalla. The academy cars run custom coolers with a fan that has brackets welded onto the radiator frame. It's an open bracket with no shroud. I meant to take a photo but obviously forgot. Not sure how good that would be on a street car but I'm confident it will work well on a mostly track driven car.
I'm waiting for Gary to report back but if the new 302S fan/shroud drops temps 5+ degrees I'm ordering one.
