- 6,553
- 8,204
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
I was actually considering mounting the cooler via the 6 Condenser Bungs. I haven't seen a good way yet to mount it to the body exclusively so half and half like you've done is one possible solution. I will look at this again later this week and see what I come up with. Always appreciate seeing others solutions. Thank you.since the cooler is primarily bolted to the upper radiator support, the front condensor support bosses on the radiator are really holding no more weight than they were when they held the condensor, I'd argue likely less since its more holding the frame and cooler assembly against the radiator than supporting it (since both sub assemblies are primarily mounted to the upper radiator support - there's a total of 8 vertical bolt locations - 4 for the cooler mount, 4 for the upper box/frame mounts)
