S550 Cooling?
27
12
Ontario
What cooling upgrades do I REALLY need?
Bigger radiator?
10R80 trans cooler?
Engine oil cooler?
Diff cooler?
All of the above?
I noticed I can probably barbecue a whole chicken in the front wheel wells, fender vents?
Time attack purposes, the tracks are small to medium , from 3 to 3.6 km, with 5 laps max on a base model 2020 GT.
Will do brake cooling 100%, brakes fade after 3 laps but how will they go with 11” apex wheels?
Is not brake cooling the issue. Is the reverse rotor. U need to change that.
U need big cooler for oil and trans. Like.. big.
U need a new radiator. The base is too small. Mishimoto is a good option
Trans cooler. Yes i repeat it. Above 108 C and u ruin your trans (which u will anyway so plan to upgrade it. )
Racelouvers.com on hood helps.
Diff cooler. It depends. 5 laps u ok. Use a leaf blower and spray some water in the front to cool down between sessions
Alessandro
Alessandro
Based on your build thread, first priorities are a huge trans cooler, an oil cooler and rotors.
For time attack on a small to medium track, you don't need much cooling upgrades. It's typical in time attack to do 1 lap at a time, sometimes sandwiched by a warm-up and cool-down lap. However, it's nice to be able to continuously hot lap for us newer drivers, to get a lot of seat time and practice. So it just depends on how much you want to drive, really. I've only upgraded the radiator on my car so far, so I do a cool down lap after each lap. Of course, if things are overheating before you're able to complete one hot lap, then that's a problem, but then you'll know pretty quickly what you need to upgrade first.
Ontario Time Attack: all events are 1 warm-up, 3 laps, and 1 cool-down.
Issue is that on small tracks ones you switch to track tires / brakes you cook the engine before you manage to warm-up tires/brakes. Or at least that's my problem. Then ones you do that there is no way you can post a good flying lap because your first one your tires / brakes not up to temp but on your second your engine CHT is high so ECU is pulling timing. Not sure how that works for A10 cars.
Is there space for trans cooler, oil cooler and bigger radiator?
would I be able to put them towards the rear for weight distribution?
A big oil cooler will help with engine cht temps too.
Also a mishi radiator helped me. (together with water wetter and 90% water. )
And of course louvers. And ducting. These are main things. You will see a dramatic drop in temp once u duct (well) and use racelouvers.
To be fair my highest CHT's are only up to 242F or so so I don't really need dramatic improvement more so I need an improvement of a few degrees so I'm out of the pulling timing zone.
@flyhalf is a great resource, several of us met up with him at Daytona and crewed to a national championship. with an automatic transmission. His car was running 170mph at Daytona, that's GT4 mph for those scoring at home. So he really knows what he is talking about with the cooling aspects of this model. He also does a lot of his own experimenting and work on the car. He would be the guy I would listen to if I had these issues because he's already been there.
I think flyhalf has both trans cooler and oil cooler infront of his Mishimoto radiator and also ducting. So I guess yeah. I only need bigger radiator + oil cooler + probably switching to 5W50 for racing season.
I do .
I use 0w40 most of the time and sometime 5w50 when i know is going to be super hot.
I also use motorkote as additive.
