captdistraction
GrumpyRacer
Fits 11-17 coyote (and maybe more):
I have a set of Trinity/13-14GT500 rod bearings and a set of 13 Boss 302 Main bearings from a build that's going in another direction. The mains have a spare in a different grade (and one position 5 grade 3 has had its back sanded to fit as it did not match the grading chart and codes from crank and block, but there is a unused grade 2 position 5 in the set). The mains may require fitting depending on your block. Works in 11-17 AFAIK, same bearing sets used in Ford Performance Aluminator builds. The ones in red X have been removed and test fit (and I have one spare not pictured). I have free bonus block hardware if anyone wants it for mock-up use. Lots of other small parts coming from this build soon.
Over $200 worth of bearings. Shipping not included, but should be very reasonable.
