CPP switch cable part number
5,263
4,261
In our swap from a auto to a MT82, everything is almost ready except the cable for the CPP switch that goes on the clutch to prevent starting the engine unless the clutch is fully depresses. Is their a easy way to render this switch null?
@Tucson302 had someone put a jumper wire between the harness leads that go to the switch to defeat it while we were at Auto Club.
Here is the wiring diagram--looks like you just jumper these two wires (black w/ yellow stripe, blue w/ orange stripe) together to tell the system the clutch is depressed all the way. http://iihs.net/fsm/?dir=710&viewfile=020%20-%20Starting%20System.pdf
