Starting with out the key switch
599
537
Hi guys, I'm stripping out my car and caging it. need to remove the key switch and wire in a master switch, Ign switch and push button start just like the race carts.. For those of you who have done this, what did you do. I cant seam to get it to start with the master and the ING switch on. I push the button and nothing. I have power dash comes on key is close to the transponder yet nothing. Master power BU-RD is to the master switch on one pole by it's self I have Key in ING, BL-GY and Lock, WT-BN on the second pole also with ACC/Run VT-GN, Start/Run is off the second pole to the ING flip switch center panel. Push to start second pole to push button to Star BU-WH. Column lock is still in place. Help !!
599
537
UPDATE: I got it to start, I removed the Lock wire WT-BN and now it starts. It will only start with the key in place to unlock the column. how to start it with the lock in place ?
Here's the info on how I did mine.
You have to keep the key close to the small black box (PATS transmitter) that mounted on the steering wheel lock.
Or you can send the ECU to HP Tuner for them to disable the PATS.
599
537
That's what I ended up doing, I ripped the transponder out of a backup key taped to the pats antenna and bang! it starts.
