Drag Radial w/ Stock Lower Control Arms
I'm asking this question because I bent the stock axels. I must have done it at the drag strip. I'm using 19" M/T drag radials. I'm also using Steeds LCA's. There is so little side wall on the 19" tires, that this occured to me. It might be better to use the stock control arms with those tires. If I was running 15" slicks I'm sure the Steeda LCA's would be better. They make the car go straighter under hard launches. So here is the question. Are stock LCA's a better choice with 19" drag radials?
