- Thread starter
- #921
- 7,619
- 10,337
- Exp. Type
- W2W Racing
- Exp. Level
- 20+ Years
More of an undertaking than I'm ready for at this moment.Looks good. I'm impressed.
Did you consider moving the motor back in addition to the seats? I know it would be a pain, but thats really the only way to get less nose wt.
Its a lot of work for sure. I've looked at it a couple times. You can get about 2" max setback before significant firewall and tunnel cutting is involved. 2" is not enough weight movement to make it worth the effort. These cars really need at least a 6" setback.
Too bad I'm not closer. I'd like to come over an check your car.
The wiring harness looks like a nightmare.
Just to spy....I mean spectate.Fabman- headed to Sonoma for SAAC 43?
Swing by Garage #10 while you're there.Just to spy....I mean spectate.
Will do.Swing by Garage #10 while you're there.
I got the Fuel Pump Controller wired in...(well Kevin did) and it's made a huge difference.Is that Weldon fuel pump the howling one or did you replace the howler with a quieter one?
