I just ordered a set of the Series 4000 T3 front and rear rotors from stangmods.com They have two more sets in stock and they had a nice price on them.
Stock are 25 & 13 so basically the same. Will be interested in how they work. What pads are you using?5 DOT 0 said:My T3 rotors arrived today and just for Gary I weighed them.
Front: 24.9 lbs
Rear: 13.4 lbs
Does anyone know what the stock rotors weigh?
My only concern with the Pagid's is their bedding in procedure. Not many places around where I live to do repeated 110 MPH brake checks. Regardless I'm 99% there.PeteInCT said:I've run rs-29 and rs-14. The 14s chirp occasionally but very little and very infrequently. Rs29s even less. With both once u bed them in they are quiet
Will do.PeteInCT said:Not as critical as that. Call me if you wish.
This seems a bit more involved than others I've used.fduboss302 said:PeteInCT said:Not as critical as that. Call me if you wish.
I too am curious about the bedding procedure...
5 DOT 0 said:This seems a bit more involved than others I've used.fduboss302 said:PeteInCT said:Not as critical as that. Call me if you wish.
http://www.braketechnology.com/brakepadbedding.html
If I was going through them as fast as you do I might get the blanks. I wanted a little bling since these should last me a couple of years with 6-8 track days a year.cloud9 said:Looks good will be interested in your report on the rotors. I'm not sure what I'm going to do next year. I'm torn between getting new DBAs and just running stock blanks.
