Ford Racing High RPM Competition Pulse Ring
I know this is the supposed culprit that kept Ford from revving the boss mototrs up to 7800 like they wanted to and this wasn't found out till it was too late.
What I'm looking for in this thread is difficulty of install. Special tools reuired/knowledge required etc.
I'm not a fan of just moving the rev limitier up to 8000 knowing what I know about the entire boss build.
You're expertise is appreciated!
http://www.americanmuscle.com/frpp-ignition-pulse-ring-1113gt.html?source=igodigital
8,670
2,638
Should be a no-brainer install, only problem is you have to take the trans/clutch/flywheel out/off to get at it. So you might want to make it worth your while and install it along with an aftermarket clutch/flywheel.
