FR Rear Sway Bar Install
I just put in the FR rear sway bar and where it attaches to the two outer brackets it wants to sit very low in them when the factory sway bar was more centered. When you guys installed the bar how did you fit yours to the brackets?
I went and pulled it off and swapped it around, it hits the left side mount for the panhard bar the other way. The way I had it instaled you could read the part number right side up.
Here is way mine is installed, if I turn it around it hits the panhard bracket on the left side. You can read the part number normally from behind. Viewed from the side the bar goes down then toward the front of the car, it looked like Gary's were facing up from his pictures.
