Register Log in
GT350R oil change made even easier!I
Badvoodoo
TMO Intermediate
Messages
13
Reaction score
17
So, there is another thread re: GT 350 oil change that is outstanding. However, I discovered the easiest soulution to oil filter change with zero oil mess.
First of all, remover the left front tire and wheel, this allows wide open access to the oil filter from the side!
Remove, oil filter access panel.
Squeeze a pint size funnel into the now open access panel. Oil funnel will sit in the hole without any help whatsoever!
Proceed with oil change.
I changed the oil with zero oil anywhere other than the funnel!
Not a drop!
Badvoodoo
TMO Intermediate
Messages
13
Reaction score
17
Obviously, I drained all the oil prior to proceeding to the above referenced step.
gww52
TMO Advanced
Messages
152
Reaction score
24
I actually did this last time I changed oil.
I was able to squeeze the funnel and slip it through the hole.
Worked great.
TMO Addict
Messages
4,861
Reaction score
1,923
Location
I have used a form a funnel on the boss. Same idea except you can shape the funnel in place. You may be able to do this without removing the wheel.
Dave_Car_Guy
TMO Intermediate
Messages
35
Reaction score
71
Location
Danville, CA
Forgive my ignorance, but with the funnel in place, how do you reach the oil filter to remove it? is there still room for your hand? It is hard to tell from the second pic. Thanks!!
Badvoodoo
TMO Intermediate
Messages
13
Reaction score
17
Dave, sorry for the delay. If you look at the first pic, you can see the oil filter and the funnel below it. Removal of the tire/wheel gives huge access from the side and the oil flows right into the funnel.
