S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
NASA ST2/TT2 Race Car
Do let us know what the best solution is.
Still researching a way to elegantly cut power using low current cables. The best solution I've found so far is the Cartek solid state isolator:
http://www.cartekmotorsport.com/Battery Isolator GT EN.pdf
The only downsides are a) Cost and b) The S550 has a current sensor on the negative battery cable that would likely need to be relocated as this device uses chassis ground. Still researching...
I like it Nick. Are you saying the current sensor on the negative cable won't allow this to shunt the ground? That would keep current flowing bypassing the unit.
No. To make this work, I'd have to attach the existing battery cable to the chassis, Then I think I'd have to move the current sensor from the existing negative battery cable to the (new) ground cable between the battery and this unit. My logic is that since there are many other chassis grounds, the only place to sense total current from a ground cable would be at the battery...
Whats this....? Vented fender liners? Why wasn't I informed....
Our GT350s have them standard.
Oh.....well, they don't share that info with us 3 valvers.
Mine were carved out of granite and the part number chiseled in.
Yeah. All the other mustangs weren’t. The rest of the S550 aren’t vented. Just the GT350 Togo with the vented fender and oil coolers and brake ducting up front.
Sent from my iPad using Tapatalk
And here I thought my fender vents were so trick....
Does anybody even say "Trick" anymore....?
I think I'm dating myself....
BOSS is a classic in both Metal and Verbiage....
