S550 GT350R Race Car Build Build Thread Profile - S550 Mustangs
NASA ST2/TT2 Race Car
There's a Red 350R from Michigan on the Chin Roster for Sebring in December. Is that you? I'll be there for that event. It'll be my first time at Sebring.
Yes, I'm signed up. Will likely run the night session too ;) and probably Daytona the week prior.
Look forward to meeting you, it's a fantastic track!
Your in Michigan too? I’m out of Grand Rapids. Gingerman is my Home playground.
Unusual, but didn't make it to Gingerman this year -- unless I sneak in a day for their last event of the season ;)
Hope to see you at the track sometime!
Unusual, but didn't make it to Gingerman this year -- unless I sneak in a day for their last event of the season [emoji6]
Will be next season for me now. I’m out of town for the season closer. Darn snow. It would be cool to meet up with others on here. Could learn a thing or two from you
The Trusty Setrab 948 :)
Looking good! I am still impressed by the factory radiator enclosure on the 350s. Very cool stuff.
Yes, the enclosure is very impressive -- even more so that the same one is adjustable for A/C and non A/C condenser fitted cars. A few air leakage paths that I'm closing off, but way better than the S197/Boss.
Have decided to go with 18" wheels for the build. Test fit my rears from the Boss (CCW 18" x 11" ET52) which fit perfectly (with a 25-28mm spacer up front):
Plan to run Hoos 315's.
Am contemplating Apex 18 x 11" for a second set.
Nick how did you mount and wire the main cutoff switch and where did you put it. The FRS 302S cars had it in the left A/C vent location which I liked.
Still working on that -- working on a low current solution so I don't need to run 1 gauge cable to the lhs of the car.
Finally decided on the main power cutoff. None of the solutions I researched was perfect, will post details on pros/cons and "How to" later, but installed a 500A solenoid next to battery:
Toggle switch, under center stack:
And wiring for a second switch in series at Driver's side cowl:
Will finish up once Lexan windshield is installed, Plan is to copy GT4:
Mounted the tires (Hoos 315 R7's) and test fit the APEX wheels today. Fronts clear the AP calipers by at least 14mm:
And with a 25mm spacer up front the (long) 350R studs are plenty long:
Shock clearance is just over 6mm. I may go to 27-28mm spacers to mimic the carbon wheel offset precisely.
