Help me with wheel/tire size and camber on my Boss 302
Sacramento, CA
I’m in need of the group's expertise and advice. After running a few track days with my newly acquired 2013 Boss 302 to shake myself and the car down, I’m ready for a set of dedicated track wheels and tires. I torn on wheel and tire size, and how much camber I’ll need to clear one of the options. From plenty of reading here, around the internet and from Apex Wheel's guides for the S197 I'm down to the following:
Option 1 (Safe Option): Square 19x10 +40, 285/35r19 200tw enduro tire.
Option 2 (Aggressive): Square 19x11 +52, 305/30r19 200tw enduro tire
Parts going on with wheels & tires:
  • Koni Yellow Shocks
  • Ford Performance Springs (-.5”F/-1”R), already on the car with factory shocks, will get transferred to the Konis
  • More aggressive track pads (G-loc R12/R10, after burning through EBC Bluestuff NDX pads in two track days)
  • camber plates (Bought MM plates, but now debating if that was the wrong choice)
  • Sway bars once initial run on new square setup
Questions:
  • What is the bare minimum camber and spacer needed to clear the 11" and 305 tire combo on the front? I read various numbers online.
  • Will the MM camber plate get me that much camber?
  • Is it worth chasing the 305s, or will the newer endurance 285s on a 10" wheel be enough to keep me happy?
*Apex Wheels is running a sale starting tomorrow and I’d like to pull the trigger on wheels then.
......I’m ready for a set of dedicated track wheels and tires.....
If truly dedicated track wheels and tires, no question imo it is worth going 305 square with proper performance tires. It's a big difference from enduro 285 tires. Keep the stock wheels and use something like a Michelin PS4 or Conti ECW for street driving and rain days at the track. This has been done a lot by now. The Apex fitment guides are excellent, they say 2.75 degrees and 25 mm spacer minimum and that's what I use. I wouldn't go less than 25 mm spacer, especially since you are using stock-size springs and strut housings which are bigger. Also, more camber and increasing the front track width as much as possible generates more overall grip, so it's a win-win.
Don't forget the extended front studs, FRPP sells a good hub and stud combo, easy to install and works well.
If you are looking for one set of wheels and tires to do everything, all weather conditions both street and track, then you might want something like a 9.5 or 10" wheel with 285 or even 275 all-rounder tires. But not for a dedicated dry track setup.
I already have the extended studs installed (did them with fresh hubs up front), so I'm setup for the spacers. Is getting 2.75 deg doable with the MM plates, or is that wishful thinking?
I love the idea of a dedicated 305 square setup (the stock wheels will be used for street driving as you said), just trying to be realistic with fitment and if a good sticky 200tw tire in 285s would keep me happy?
