Since my last trip to Limerock Park I started getting P0010 and P0012 codes. It can pop up randomly, even under very tame street driving. I am VERY hesitent to take my LS back to the 2 local Ford dealers, neither one of them had any allocation for a Boss in 2012 (LS or otherwise, although they did sell some GT500's) and they both don't have a very solid reputation for service (envision monkeys banging on the transmission with bats and hammers...). Just the fact that I have the LS air splitter on a car that's lower than stock AND I have racing pedals causes me concern for who's driving it. I already almost had her dinged up twice because of 'apprentice' techs that think they can drive the car (almost crushed air splitter on one of those cement parking barriers you see in a parking lot between spaces; almost put the car through a wall when they hit the brake and also the gas at the same time
Because of all this I am tempted to swap out the Bank 1 camshaft posiiton sensors myself and see if it helps the issue. My only other recourse I have is to drive 1+ hrs to the dealer I bought her from but I suspect that will come with tit;s own set of headaches (trailer the car, have no appointment yet, etc, etc)
My Questions (Bill Pemberton I hope you're listening ! ;D )
1) I know my issue may be just a bad connection. I have yet to play with the camshaft position sensors. Is it advisable to pop out the connectors and apply dielectric grease?
2) I have yet to investigate how easy/hard it is to remove these sensors? Does anyone know what I'm up against ?
3) If the sensors are easy to replace mechanically, can they just be swapped out and reconnected - or is there a whole process to have the PCM adjust to the new sensors ?
4) When I do get the codes I see or feel no issues with the car at all, no loss of power or smoothness of engine. Is it possible these are codes that can be 'ignored' temporarily (Like the P0300 crankshaft position sensor code that just needs the relearn...) until I get back from my next event ?
Any info you guys may have on this topic would be greaty appreciated. I have an event in 1 week at Watkins Glen
and would like to put this issue all to bed ASAP.
-Pete
-Pete
