Lap Time Thread
Ne PB at Watkins Glen, though it should have been better.
2018 Mustang GT PP2 Race Car ST-2 class legal, Hoosier R7 295/35-19, ARH Headers, Cortex JRi Coilovers. 2:06.02
That was pretty , sure looked like you hit all your marks! I wonder what a set of 315/30/19 Hoosiers would do for you .....2:04? Thanks for posting as the majority of TMO members viewing this are just envious you got to run Watkins Glen, I know I am!
Year/Make/Model/Trim: 2011 GT 5.0
Track/Course: Blackhawk Farms
Best Lap Time: 1.23.64
Tire: 305/680/R19 - Conti Slicks
Suspension: Tons of cortex bits, JRi coils
Brakes: 4pto Brembos, St47 front St43 rear
First time to this track with this new car. Going back in August and going to push for the teens.
@Black Boss and @2012-Boss were in the 2:02s for their bests. My car is capable of getting there, Turn 9a is where I lose loads of time, can't find the balls to carry more speed through and get to throttle early enough on exit. Will have the 315 hoosiers and sticker Michelins for the October NASA race event though.
New personal best for me as well.
Laguna Seca:
2006 Mustang GT Coyote Swap. Full Cortex Everything on Hoosier Scrubs. 1:35.850
Just in case anyones keeping track, that’s 10 full seconds faster than my first time at laguna…..and back then I had 200 more hp.
High Plains Raceway
2019 GT350 Stock except Vorschlag Camber Plates
Goodyear supercar 3r 305/30 19 tires square on Apex SM10s
2:04:00. Second track day with this car on a open track day, so some minor traffic.
I didn't get video on that PB lap because, you know, technology! But here is a 2:05 lap from my last track day. Any critique welcome.
Update on my Sonoma time: 1:55 in a 2019 GT350 on FP springs and Goodyear S3R tires
Seeing what others on here can do, I know I can shave off another 5+ seconds.
For your info .you are right. Sub 50 is absolutely doable.
Some points.
T1. Hold speed more. Flat till passing the apex of the wall then lift.
T2 be disciplined. Off camber turn .If u tap throttle before apex it means...you arrived too slow and feel the need to give something.
T3. Little more aggressive with throttle.(give some in between.the change in direction.
T5 is flat out and let the car go to the left (while.you remain all the way to the right)
T6 carousel. Start in the middle .nice apex but trust you and the car and flat out.
T7. Not bad. Try to be slightly closer on first apex. And on exit use all the asphalt. You pay for all lol.
Esses. Nice but little too early apex on the last one and you stay too much on the right. Use the curb on the left.
T10 can be way more aggressive. But...it is t10 so i understand
T11 instead of coasting.. apex later (after 3 set of tires.
Lines are good overall. A stock GT on 3R can do 48 . I'm sure you can get there soon!
Good job and i hope you had fun!
First time in the Mach 1 at MPH ( Motorsport Park Hastings ), won my Class and set a time of 1:35.526 on the 2.15 mile track.
2021 Mustang Mach 1
Apex 11x19s
Apex 25mm spacer up front
Michelin Pilot Sport Cup 2s ( 305s in front, 315s in the rear )
EBC SR11 brake pads
MGW Shift kit
LTH resonator delete
Ford Performance rear seat delete kit
The track is definitely faster and though I am not hitting the top speeds I could with the Boss S, the new pavement gives one more confidence in high speed turns and you can brake really deep. I have to say that the Mach 1 continues to impress me, even though I have little seat time, it is a lot closer to the Boss S than I expected. Needs more HP, but the handling is insane for a car that weighs close to 2 tons with driver and a full tank. Where I would lose time on the straights I made it up on powering out out of turns -- the independent rear sits down, plants and goes. Of course since baby has some back ( and front ) it is no surprise she squats and goes, ha.
Finally getting my time down. a while back I turned an undocumented 152.xx and since then have been stuck at 157.XX
Sonoma Raceway Aug 7. 2022
153. 28
R spec aero
FP springs
MM camber caster kit/ maxed out at about 1.9
Goodyear 3R 305/19/30
Learned to do heel / toe on my own.
Lost some weight and the car did also. HAHA
Year/Make/Model/Trim: 2020 GT350
Track/Course: Road Atlanta
Best Lap Time: 1:39.959 (twice, to the thousandths!)
Tires (Size & Model): 325/30R19 Goodyear Eagle F1 SuperCar 3 square
Mods: suspension
My camera went pear-shaped late in the day, so I didn't get video of either session, so here's the TrackAddict shots:
I did, however, capture a low 1:40 earlier in the day chasing Everette!
Next event:
Track/Course: Barber Motorsports Park
Best Lap Time: 1:40.259
Mods: suspension
I didn't get the 1:3x that I was shooting for - hot weather, rain, and boiling my brake fluid (yike!) limited my laps.
Byron, pretty obvious you are a driver who takes his time, warms up his tires and then hammers the " loud pedal ." Thanks for sharing your best run, it was fun to watch. ChipG, congrats on the 1:39 at Road Atlanta, because everyone who knows that track knows that getting into the 1:30s is an accomplishment. Bet you get over 150mph next time you are there. By the way you are cooking through the esses my friend!!
Ran VIR today, TNIA event. This is my third TNIA.
2019 6spd GT PP1 - completely stock. Rear tires MPS4S, front tires p zero Nero all seasons (don’t ask)… Stock sizes 255/275.
Not sure if this is an okay lap or not but The best lap is in the picture. the front tires are shot now, extremely glazed over. Ordered a 19x10 square setup and replacing the fronts with a 275 to match the rear.
Not asking about the tires but I'm sure other will agree. Don't mix match tires on the track. As far as lap time I have no idea because I am not familiar with VIR. But have fun and be safe.
