Leaking engine oil pressure sensor (with pics)
Discussion in 'GT350 and S550 Technical Forum' started by THX 138, Jun 11, 2018.
  1. THX 138
    THX 138 TMO Intermediate
    29
    36
    Apr 7, 2017
    Indiana
    Posting this in case it might help somebody else. After a track day on Saturday, I noticed that I had a belly pan full of oil, and I was down a quart. I figured it was probably a loose oil filter (even though I ALWAYS torque mine to spec), but I looked at the Sharpie marks I made when I tightened the oil filter, and it hadn't moved. Odd. Must be something else...
    I cleaned up the oil and kept looking for where the leak was coming from. It wasn't until I actually started the car and then got back underneath that I realized the oil was coming from somewhere above the flat, round oil plug (see the first pic below). I traced the leak up to the engine oil pressure sensor... Bingo! The factory witness mark showed that the sensor has backed off a quarter turn, causing the leak. (See the second picture below.)
    The good news is this should be a simple warranty item ( I just hit 2 years & 8,000 miles), and it will be easy to keep an eye on in the future, since you can see the sensor when you remove the driver's side front wheel. So, be sure to check your engine oil pressure sensor before your next time out on track.
    JeffV8, fpGT350, reconracing and 2 others like this.
  2. ArizonaBOSS
    ArizonaBOSS Because racecar. Moderator
    8,047
    1,572
    Dec 6, 2010
    Harmonics. Good eye.
  3. VoodooBoss
    VoodooBoss Rick Moderator
    20,076
    2,510
    Nov 30, 2010
  4. steveespo
    steveespo Lord knows I'm a Voodoo Child Moderator
    3,381
    613
    Mar 6, 2011
    NY Metro
    <iframe width="854" height="480" src="" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
    Mad Hatter likes this.
  5. SVTMatt
    SVTMatt TMO Intermediate
    23
    17
    Mar 15, 2016
    Thanks for the info @THX 138 , I just ran into the same scenario. Getting scheduled to get it fixed now. Anything additional learned after the fix?
  6. Grant 302
    Grant 302 OPM Spent: $587,402 Moderator
    6,432
    1,501
    Nov 23, 2011
    In the OC
    Check your oil sensors...
    Report of 3 loose leaking sensors at WSIR this weekend (one R and 2 350s). A fourth popped the engine...didn't hear the cause yet.
  7. ArizonaBOSS
    8,047
    1,572
    Dec 6, 2010
  8. VoodooBoss
    20,076
    2,510
    Nov 30, 2010
    YIKES YIKES (that's double yikes)
    ArizonaBOSS likes this.
  9. Grant 302
    6,432
    1,501
    Nov 23, 2011
    In the OC
    Kinda worse than YIKES for me. Confidence in the shakedown runs would be really low. Two of those were my friends' cars and one of them has had several track days on it already over the last couple of years. Not sure why it would shake loose now.
  10. Mad302
    Mad302 TMO Race
    339
    111
    Sep 2, 2014
    Waco, Texas
    Time to go out and check mine. 1100 miles
  11. TMSBOSS
    TMSBOSS TMO Addict
    3,717
    940
    Aug 23, 2011
    I have never used it....but.
    Can a locktite product be used as a thread locker and sealer?
  12. 11GT50
    11GT50 TMO Intermediate
    47
    40
    Jan 18, 2018
    Union, WA
    VoodooBoss and Grant 302 like this.
  13. TMSBOSS
    TMSBOSS TMO Addict
    3,717
    940
    Aug 23, 2011
    Nice. A little carb cleaner on the threads before applying and it should work.
  14. Creedog
    Creedog TMO Intermediate
    23
    5
    Mar 21, 2018
    GA, USA
    How well has it worked? Any concerns/issues after using it? Can you pick it up at any main auto parts store or have to order it online?
  15. TymeSlayer
    TymeSlayer Tramps like us, Baby we were born to run...
    2,323
    1,078
    Dec 12, 2011
    Brighton, Colorado
    You can use Loctite 567 High Temp Thread Sealant. It prevents leakage and loosening from shock and vibration.
    (Nothing against Permatex but they are second Banana)
    Eric62 likes this.
  16. racer47
    racer47 All I got left is fast
    196
    207
    Jan 8, 2017
    SE WI
    Good info, I didn't know that existed but I will use it now.
    I agree that Loctite used to be king, but since they now own Permatex, the products are likely to be more similar than different.
    https://www.permatex.com/announcement/1972-2/
    The Permatex Company has a New Owner
    Posted on: January 19th, 2016
    The Permatex Company was sold to Loctite Corporation. The business was moved to Cleveland, Ohio and integrated with the Woodhill Chemical Company. In the late 1970’s, Woodhill Permatex launched Permatex® Blue Silicone which went on to become the largest selling blister carded chemical item in the American auto parts business.
  17. TMSBOSS
    TMSBOSS TMO Addict
    3,717
    940
    Aug 23, 2011
    I keep learnin and learnin.
  18. 11GT50
    47
    40
    Jan 18, 2018
    Union, WA
    It seems to be working well but I haven't inspected it in a while and have only had one track day since the repair. I initially found the leak because I could smell oil when I got out of the car. The twisted wires were the only thing that prevented the sensor from screwing completely out and I found oil dripping off the back of the belly pan.
    I could not find it in any of the local parts stores and ended up ordering it through Amazon.
  19. VoodooStang
    VoodooStang TMO Intermediate
    33
    62
    Jun 1, 2017
    Charlotte
    Thanks for the post on the oil pressure sender. Discovered that mine was finger tight.
    THX 138, Grant 302 and VoodooBoss like this.
  20. Grant 302
    6,432
    1,501
    Nov 23, 2011
    In the OC
    Better now than later. I'd suggest checking everything. Another 350 owner found a leak in one of the cooler lines.
Share This Page
