NEW OWNERS-----Tighten your lug nuts
Boomerstoys
Keep the shiny side up & the rubber side down!
Just FYI. On page 22 of the Boss 302 Supplement it states you should retighten your lug nuts @ 500 Miles.
Man, am I glad I checked! Was nice here in Seattle so I thought lets go for a ride, and decided to just check them before we left. Sure enough, the rear wheels on both sides were loose. Fronts were fine.
Check them to be safe!!!
Cheers!
PeteInCT
2,848
14
Nah. Ya think ?? ;D
You should check your lug nuts very frequently, especially with temp changes. If you track your car you should check after each run, at least until you get to know how it reacts to extreme temp shifts.
PeteInCT
2,848
14
I believe the manual states 98 or 100 lbs, I don't recall exactly. I do remember it's above the 90 lbs that my Audi's were spec'd at. It is in the manual...
Boomerstoys
ArizonaGT, agree, the burnouts by the dealer plus everyone knows that RACE RED is the most powerfull and fastest color ;).
Torque value is 100 ft. lbs. per the Boss Supplement. Think a lower value is stated in the regular manual.
Always check my lugs BEFORE each session when the wheels are cool. Don't want to over torque when the wheels are hot after a session. Good habit to form.
Cheers!
1,255
GA
ShaneM said:
if you track the car, check it after each session. I've had them loosen to the tune of 50ft/lb during a session.
It sounds like you were driving the wheels off your car - almost literally ;)
Bossfan said:
Why would the need for retightening lugnuts on a Boss 302 be any different than the needs for any other car? Is there a technical reason here?
No, unless you track the car or really drive crazy on the street and heat up the brakes more then normal.
I was surprised at the way one of the mechanics torqued the lugs on one of Roush cars. He did it very fast while the cars was rocking back and forth. I get someone to hold the car at the track or let it roll forward before I do the torque, it was interesting to see this.
