I will be at LRP on 3/31 with NASA and 4/9 with SCDA. Probable on 5/31 with SCDA.
Jza1736 said:Yes on may 31st being the consensus and yes they should send you an email. What run group did you sign up for?
PeteInCT said:If you've never been to an event before Ian Prout will make sure you are in Group 1. You will be assigned an instructor who will sign you off as he deems fit for solo. Most drivers in most organizations do not get to solo in their first event so don't let that get you down if that's the case. Limerock is hard on brakes, especially for novices, since it's mostly turns. I have found my cars have run hotter there than tracks with very long/fast straights. The Boss is easily capable of over 135 MPH even with LRP's short single straight. A very experienced driver will hit 145+ on this track. That said, don't expect to hit 125 if this is your first time out, and top speed is NOT the important thing here - it's smoothness and awareness of the track and fellow drivers. Speed comes with time. If you try to be fast, you won't be. If you try to be smooth you will be fast. Minimally, you want to get rid of your stock brake fluid and replace it with a high performance fluid like Motul 5.1, Motul RBF600, ATE Super Blue, etc. there are more expensive options like Castrol SRF but you won't need that level right away. Your PFC pads will be Ok for a while, if you intend on doing more track days you'll want to seriouosly consider more race capable pads.
Have fun - be aware of those around you - and think SMOOTH....
Jza1736 said:Just come with an open mind to learn and to have fun. Don't look to set any track records. The car is a blast to drive.
Here's 2 YouTube videos you can check out to start learning the turns. I find it helpful on a new track to watch the videos to get accustomed to the track before you get there.
1: boss 302 at Limerock park 11/14/11
2: bill auberien - a lap of lime rock park - April 27, 2010
Badhorse said:Ok, I'm registered. My car has not even been built yet, but I'm registered
PeteInCT said:I will be at LRP on 3/31 with NASA and 4/9 with SCDA. Probable on 5/31 with SCDA.
roketman said:My car Passed with no plates and a Corsa extreme muffler.
