I know there's been many threads on when to do the first oil change and what oil to use, so this is just a few tips I've found after much searching here and online. I'm sure this is so basic for most of you wrenchs that it wouldn't be discussed, but for someone like myself I thought it could be helpful to others like me.
1st oil change at 1250 miles
motorcraft 5w50 full synthetic, motorcraft fl-500s filter. bought from k-manparts.com oil $8 per qrt, filter $5.50
used a form-a-funnel to make the mess limited under the oil filter, which worked great. no mess whatsoever. a few paper towels under the edge of the filter housing along with the form-a-funnel made it a clean endeavor. I bought the form-a-funnel on amazon, through buzzard gulch, it was $25 shipped. the 6.5"x14.5" size worked well.
while I had it up I took the exhaust restrictors out, it sounds bad arse but not too loud.
