So I put my Boss on jack stand and removed the front fascia to get some measurement for the oil cooler line and oil cooler placement.
I was set on getting a setrab 948 and mounting it sideway. (Cooler port on the side instead of down).
Well now I'm not so sure anymore and I think the setrab 660 maybe a better choice
Here's why :
Setrab 948 BTU range : 69000-96000 and core surface : 14.09*14.7=207.123in2
Setrab 660 BTU range : 63000-90000 and core surface : 11.14*18.31=203.9734in2
Now the upper grille opening is wide enough for both cooler but it's only 7" tall
Setrab 948 7*14.7=102.9in2 is on the direct air pass the rest is behind the bumper.
Setrab 660 7*18.31=128.17in2 is on the direct air pass the rest is behind the bumper.
As you can see the 660 is at least 20% more surface area in the direct air pass
And the 948 is only 5% bigger.
Please correct if I'm wrong.
Should I get the 948 which is race proven or get the 660 which seems to provide a better cooling?
The 660 is only 1$ cheaper than the 948 on Improvedracing so price is not a problem.
Thanks
Here's why :
Thanks
