Oil Temp gauge
Hi Guy's , I am installing a digital oil temp gauge, now I would appreciate a little bit of help with the wiring. i need to find a positive source ( ignition ) any suggestion in the pass fuse box?
Also there is a orange wire that is suppose to be plug in a headlight positve signal, since the gauge is digital I cant use the dimer switch because it will flicker so it need a positive source to dim the gauge by about 30% once the light are activated...
Thanks for your help
