- 170
- 37
I finally got back to the track after installing my gauges.I have oil pressure,oil temperature measured at an oil filter adaptor after the cooler, and water temperature measured at the block heater fitting.I also have an S model grill.I was especially interested in oil temp.
Running pretty hard today at Watkins Glen,outside air temp 50 degrees.The water temp was rock steady at 192 degrees.The oil temperature got up to 260 however.I guess I'll be looking at an engine oil cooler for next season,260 is about as high as I want to see it.
What are those of you who have a cooler using and what kind of temperatures have you been seeing?
Thanks, Guy
Thanks, Guy
