CaliMR said:Trying to score pics of her louvers...nice
2boss2's said:Here they are installed.
Justin said:Did the older mustangs come with louvers back in the day? Or was it an aftermarket affair back then too?
Louvers just remind me too much of the late 80's IROC Z's that used to roam around town back when I was in HS.
Just cuirous does anyone have a inside looking out picture?
racered302 said:Well I decided to take a break and do an update on my install. The louvers do look great but if everyone is as anal as I am about their car then beware of the install. The installation flyer you get really sucks. It seems like it was layed out in CAD but never tried in the real world, like the one we live in. I trashed MRT's template and made one of my own so I could get the hinge mounts set and it worked great. You really do have to be diligent when setting the mounts because you have a near zero tolerance. I looked at the drawing for the hinge placement ( CAD Drawing ) and there is no way that the hinge will line up with the roof line unless you hang the mount over the gap between the window and the roof. The instructions are a joke and I'd suggest working things out on you own, must have been out sourced to China. Enough complaining.
When you install this thing mount the lower latches, install the foam tape between slate 2 -5, file each the hinge slots out about 1mm for adjustment. If you follow there instructions you end up moving this thing around more then you want and can potentially scratch something. I've been lucky so far but I've come close, I was trying to do exactly as they wrote it but enough is enough. If anyone wants a step by step and the measurements for placement on doing this, it's pretty much burned in brain now just say so otherwise I'll just bury this experience and move on. Thanks for letting me vent, back to work. I'll post pics when I'm done, Like it or not.
