Re: CEL - "random misfire" (recurring)
After doing the Decebler 12th PCM GT 5.0 re-learn it did it again, and again. I too felt it was now a safety issue as it would power down when entering the Highway from work.
Over the course of a few weeks we determined the Crank Sensor may have been the culprit. The hard part was getting both Ford and Ford Racing together on what it really needed as I had the track key put on and then started getting the misfire codes.
In the end the service advisor and my Tech figured it was best to get the Misfire thing fixed and then I will add the track key back on.
It may not be a TSB but I think it is in the works. In order to replace the crank sensor they need to pull the tranny. then they order the new sensor kit and dont forget to get new Flywheel bolts as this added a day to my repair. Sensor, Ring, Retainer, Pilot bearings, several bolts, seal assembly… Misfire relearn.
At this posting I have driven about 400 miles over 25 starts over about 3 weeks with no issues. I was told to take a longer road trip (minimum 40 miles no stopping) to make sure all is good to go, giving it time to go through all the programing relearning codes??? I will then add back on my track key. Hope this help's!
