cloud9
Gary
Re: CEL - "random misfire" (recurring)
Sounds like there's a decent chance it was low fuel then.
Jimmy Pribble said:However, I drive on a really bumpy track and I still think extreme vibrations are a factor.
That's basically the explanation I got back in May 2011 as far as the cause.....now what's the fix??ArizonaGT said:I believe you're right about this; the computer makes a baseline to tune out "normal" vibrations but hard bumps in the road or track could push the computer outside its comfort range here. I did notice that my misfire limps at Chuckwalla typically occurred after two things happened in rapid succession:
Hitting a large curbing with one side of the car, under heaving braking, then going to WOT in 4th gear from around 3500-4000 RPM (high load).
Previously when I encountered the misfire limp in Arizona it was after going over a large hump in the track that unweights the car, and being at WOT under high load 3500-4000 RPM in 3rd gear during or just after that bump.
Both of these scenarios also involve right hand turns, FWIW.
Yours is worse than most but many of us have been experiencing this. It's very frustrating. Ford does read this forum and I sure hope they come up with a solution soon. My fear is now that the cars are out of production they forget about us.shoveldoc said:Update to my previous post. i have been driving the car for over a week since they did the updated tcb and the Ford engineer worked on the car. It worked pretty well for a couple of days, but i have now been getting the cel/mis-fire almost daily combined with the solid check engine light and crank sensor code. I called the dealer and they contacted Ford. Ford will be sending the engineer back out next Tues. to work on it again. We'll see what happens... although now going on my eight time taking the car in for this same issue, i am not too hopeful.
I can't speak for everyone, but myself and many others posting in this thread run with AdvanceTrac off, which is as much as you can shut them off.racered302 said:I may be out in left field, but does this happen with electronic nannies turned off? I'm asking because my bimmer will stall if I'm stuck on ice and try to keep the rpm's up to get unstuck. I have to turn the nannies off. It's a different situation but it still backs everything off until it's happy. Could the hysteresis setting be out of tolerance?
PeteInCT said:By now I cannot believe you do know know that these are real, they are common, and they are causing anyone who seriously track drives the car a number of issues. I personally have almost lost control of my Boss when I lost power to limp mode while in a large radius high speed turn at Mont Tremblant. We really need assistance here to keep these events safe and allow us to truly enjoy a most remarkable car.
-Pete
