Re: P0300 & Limp Mode Questionaire
If they checked it then your harness is probably fine. The tests that they ran on my car supposedly pointed to to the harness as an issue and FRPP told them to swap it out. One thing that you can check is if you pull up the connectors to the camshaft sensors and look in with a light and a magnifying glass - look for little flakes of gold. If you see any then they have work to do on your harness. This check was told to me directly by a Ford Boss design team member. And this is why 2013's have different connectors....
On the pads, I'd love to have you try a set out. Carbo's are good pads - outside of Pagid they are the only other ones I'd use. I have used both (on my Audi TTS) and decided on Pagid long before I started selling them.
KBBOSS1086 said:Pete - The service report from my last visit to the dealers in August (before I gave up trying to get it fixed) states that they inspected the coils and boots and did the misfire re-learn. I've suggested to a couple of the dealers that the problem could be in the wiring harness and/or CPS but they only ever do what the "hotline" tells them to do.
The misfires don't occur that often on the street...maybe 4 or 5 times in 13k miles. I'm going to keep my fingers corssed that this new program works and if not, take up my battle again in the spring.
Thanks for the suggestions and all the info. And congrats on the Pagid distributorship. I've been using Carbrotech xp12"s / 10's but will likely be contacting you in the spring to give the Pagids a try.
