Even though I am using stock springs, the DS was definitely not centered, and was proud on the driver side by about 1/4-3/8". Not much, but noticeable with stock wheels, more with the new ones. So while changing the diff lube I installed an adjustable aluminum PHB. The stock one had to be banged out a bit, and pried out, since for some reason the mounts were super tight. The new bar had to be tapped in, also.
Question 1: Is it possible to over-tighten the bolts? I definitely noticed that the sheet metal mounts crushed inwards quite a bit as the bushings deformed. The instructions said 130ft-lbs, I did 100 and even that seemed like too much. The metal bushing piece inside was about 1mm shorter on each side than the bushings. Should that have been longer? I bought the PHB a while back from AM and maybe it is not really for a '12?
Question 2: Why would Ford put tons of BBs in the PHB??? Vibration dampening? When I picked it up it was like one of those hollow logs with pellets that make rain sounds, lol. Felt like I saved close to 6lbs with the new one.
