Photos
Fomoco302
Life is short. Live well!
OK I know this is not a new topic but I guess I am just a dumb a** cause I cannot figure out how to post photos. I've read the instructions many times but no luck. So if anyone would care to call me send me a pm and I'll give you my number. I am on central time.
HELP !!!!
First, upload your photos to a site that will allow you to store your photos to it, such as imgur.com. Then from there you can get a URL for each photo which you can copy and paste into a thread/reply with "img" in front (minus the " " and surrounded by [ ]) and "/img" after the URL and it should embed the image.
Fomoco302 said:
I have the photos in Photobucket but when talk turns to url's and links I go blank.
When viewing your library in Photobucket hover your cursor over the picture you want to post and then over the little gear that shows up in the upper right-hand corner. A white box will show up - click on 'get links.'
Now a large white box will appear in the middle of your screen. Click on the words 'IMG Codes' toward the bottom. The box immediately below will turn yellow and say 'copied.'
Now go to your post where you want the picture to appear and while holding down your 'Ctrl' key press the 'v' key (Ctrl-v). This will copy the IMG Code into your post. After you've completed your post the picture will show up here as long as you leave the code you just copied in the post.
Hope that helps.
