MoscowBoss
BOSS 771
Would appreciate any photos or install details from those that have recently installed the new BOSS exhaust cutouts from QuickTime Performance.
Thanks in advance.
Ed
Thanks in advance.
Ed
MoscowBoss said:Would appreciate any photos or install details from those that have recently installed the new BOSS exhaust cutouts from QuickTime Performance.
Thanks in advance.
Ed
Not yet. I am out of the country for a couple more months. I plan to install them during the holidays at the end of the year.jeepinocala said:MoscowBoss said:Would appreciate any photos or install details from those that have recently installed the new BOSS exhaust cutouts from QuickTime Performance.
Thanks in advance.
Ed
Did you ever buy them?
You need to use an external photo hosting site to post photos.jeepinocala said:Have not been able to get pictures posted on here but I do have them they are a very good qualtiy part/system real simple to setup and work absolutly great I can only say if you are thinking of buying them then just do it you will be happy they are very well built. Worth every penny they cost.
boss2012 said:just installed my QTP cutouts Friday. Took about an hour and half on lift. ran wiring a little differently. Cut 1/2 hole in the frame rail just beside cutout motor and ran wires through frame rail to the front of car then up behind fender liner through existing holes near strut towers (no cutting or drilling there) brought driver's side over to passenger side under windshield cowling. Mounted wiresless controller beside power block under hood and tapped into spare fuse spot in power block. no exposed wiring and no mounting inside cabin at all.
Dark Horse said:boss2012 said:just installed my QTP cutouts Friday. Took about an hour and half on lift. ran wiring a little differently. Cut 1/2 hole in the frame rail just beside cutout motor and ran wires through frame rail to the front of car then up behind fender liner through existing holes near strut towers (no cutting or drilling there) brought driver's side over to passenger side under windshield cowling. Mounted wiresless controller beside power block under hood and tapped into spare fuse spot in power block. no exposed wiring and no mounting inside cabin at all.
Did you add the 5/8" holes that came with the original exhaust disks so that you retained the stock exhaust sound when the cutouts are closed?
did not leave any holes, the QTP is not just open or closed. I can stop it at any point to give a variance in the sound level. It takes about 5 seconds to open fully so if you just stop after 1 second only partially open.
boss2012 said:just placed my order friday afternoon for the QTP cutouts with remote. $386 and will be shipped on Monday. Hopefully will have by next weekend and let you know what i think. It will be a shock after 2 months of no restricter to be able to get in the Boss and dial it to the mood i'm in at the time (especially if wife is in car)
