Racing Oil
Never seen it before but it looks a bit expensive. Catch Mobil 1 on sale and with the money you save you can buy me a beer!
http://www.superchevy.com/how-to/additional-tech/1312-driven-racing-oil/
680
215
I'm using this. It's more than decent. I spent allot of time to research mPAO, specifically the base manufactured by Chevron Phillips (Chevron Phillips is a chemical producer jointly owned by Chevron Corporation and Phillips 66, it is not a Chevron product or a Phillips product so please don confuse their base oils with ones used for either brand). Driven buys from them specifically and it's uses Lubrizol additives in the blending process.I'm by no means a chemical engineer or an engineer on any level so I wanted to make sure I understood what this stuff was and why what sets it apart from PAO. It has the best air release properties (read low foaming, super critical for engines that rely on oil pressure to manipulate cam timing like in the Coyote motor). It has the best viscosity index at from the start (before index improvers are added). VI can be raised by adding tons of improvers to a base but that will not be shear stable (think Motorcraft 5W-50) for very long. I recommend checking out their videos on Youtube if you want to learn about engine oil in general. Even if you don't have interest in the product, you will learn a lot. With all of the BS on the forums surrounding engine oil and understanding viscosity, it's refreshing to see someone talking straight. Even better, if you call their tech line, you can talk to Lake Speed Jr; Ive learned allot from him myself. So much so that when I was at SEMA this year, I made it a point to stop and thank him for all the insight.
Tucson 302
2013 Black LS #439
Thanks for the link, I will buy you a beer either way :)
