Royal Purple
1,022
97
Texas
I am looking at changing my transmission and rear differential fluid. I am stationed in Germany and have Royal Purple available to me there. Does anyone have any experience with Royal Purple SYNCHROMAX – MANUAL TRANSMISSION FLUID? Also, Royal Purple MAX GEAR – HIGH PERFORMANCE GEAR OIL in 75W-140? If anyone has used these products and has feedback or recommendations it would be appreciated.
Thanks
A friend of mine installed the RP products in his 2012 Boss tranny and diff and it is working fine. I'm running Redline in mine and it is also working fine.
PeteInCT
2,848
14
Fly - Rumor (and only that) is that RP uses graphite in their lubricants which can promote sludge and excessive wear. I have no idea is this is true and have yet to find any empirical evidence to disprove the negative press you can find in forums, however it has made me personally leery about using RP in my high performance vehicles. I use Castrol, Motul and Redline products in my Boss as well as in my former track cars and have never had an issue.
In Germany, I would assume the following would be available, if not many more brands I am unaware of: Motul, Castrol, Elf, Agip
Sesshomurai
Thanks
I use it. Works great. I've tracked the car a few times with it.
ace72ace
1,242
71
I will be using RP in my engine after I dump the Motorcrap oil. I will also be installing an oil catch can this winter (leaning towards the Moroso model as shown on a BMO thread) and will be checking the can carefully. My guess is that my car won't accumulate a lot in the can as my car hasn't required me to add oil since new. Looks like the level has moved down the hash marks on the dipstick maybe an 1/8th of an inch from dead center.
I'll report back next spring on how my Boss likes RP, as well as the OA report on the Motorcrap fill.
PeteInCT
2,848
14
What was that tell you about long term adverse effect to the engine, for example affects of graphite additives? I think the lab analysis info is very valuable but it's not the whole story.
1,022
97
Texas
darreng505 said:
Thanks
Thanks everybody for the reply. That is why I love this forum, there is a lot of knowledge and experience in our forum and we share it. I am going to give Royal Purple a shot in the Boss. I use all of their products in my truck and so far so good. To the comment on buying other oils available in Germany...I try to avoid buying on the German economy because you end up paying twice as much for the same product. Thanks again
ace72ace
1,242
71
Just completed my RP oil change & Fumoto valve install last Sunday. Very pleased with how it runs and drives. 8.5 qts went right up to the 2nd dot on the stick, and I don't anticipate it moving much at all off that mark for a long time. I was lucky to get one of the Boss engines that doesn't gulp oil. Ooorah! Pix and vid coming in another thread...
mine does not use it either. im also a lucky one.
graphite from what i know will contaminate the o2 sensors. with the car being a wide band setup i think thats why they are asking for a low graphite ppm count. but does 100-200 ppm really change the ball game?
