Safe distance between tire and strut
Hi guy's, I got a set of 18x10 BBS (Ford Racing) wheel for my Boss . Tires are 275x40x18 square. It clears the Brembo's and are not rubbing anywhere but seems a bit close to the strut, about 1/4 inch. I dont have camber plates or bolts as for now but I will eventually. Any thought on this?
Is it right to say that camber bolt will bring the tire/wheel closer to the strut and camber plate wont since it move the hole strut together...
steveespo said:
I don't know, that looks awfully close, especially with stock camber. Aren't there 18x9.5" specifically for the fronts. Darren probably has good info on these wheels.
Yes BBS MAKES 18X9.5 but I wanted a square set up and according to Ford Racing 18x10 fits our car w/o problem. They suggest a spacer to clear race brake ?? but dont say anything about the close fit in regards to the strut
gain as much camber as you can by moving the struts in the factory holes first. then add your camber bolts and make up the difference. every chassis is a bit different so you may or may not need to space the wheel out. a 5mm spacer should be the max you will need (if anything).
