Spring compression?
Sesshomurai
Hey guys,
I'm noticing my passenger side ride height is a quarter inch higher than the driver side. What could cause this?
Is it just that I sit on the one side and drive mostly right turn tracks? Any way to correct it?
thanks.
7,286
4,810
DGRacing said:
Hey guys,
thanks.
Front or rear?
It's possible aspiring is not properly seated on its perch.
Sesshomurai
TMSBOSS said:
Front or rear?
It's slightly more pronounced towards the rear
JScheier
Too Hot for the Boss!
The rear springs all have flat pigtails... if you are running OEM style springs in the OEM location... so it's rarely them (although if the rubber pads are not seated properly, it could cause some variance).
For the fronts, the springs have pigtails that sit into the upper and lower perches (OEM spring style, OEM perches). If the pigtail is not seated in the perches correctly, it can lead to ride height differences.
Of course, if you have an adjustable ride height suspension, any one of the corners could be a little 'off'... although if that gets the corner balance correct, you will probably have to live with it.
There could be suspension bind causing ride height differences. Adjustable sway bar end-links set in bind, bushings tightened in bind... all sorts of little things like that.
Could just be the way it came from the factory.
four-walling
Kerry, San Diego
DGRacing said:
Hey guys,
thanks.
Anybody ride much in the passenger seat?
Sesshomurai
Nope.
Oddly enough, I took a level to the rear wing and front splitter. perfectly level...strange.
