The sticking shifter mystery continues any ideas?
I’ve just installed a t56 magnum xl it’s cost me $7500 and I still have the rear gears to change out. Didn’t buy a full clutch kit either, just the 26 spline fiction plate
This guy is low bucking it right now, if you buy the mgw, and it works, great, but prolly it won't, then you'll have it lying around. Stop, take a deep breath, if you're in Fla,.I have a rebuidable mt82 sitting in my garage, take it, have it built, put it in your car and then just give me back your Trans. This way the car stays drivable for the longest amount of time, and Trans swap should be done in a day. All I need is a rebuild able core for some future date. Just don't Jones me on the deal.
Why is " Trans " capitalized in.spell check. WTH?
So
I agree with others that your problem is not the shifter. Nor do I think it’s your synchros. It really seems the root problem is your clutch isn’t fully disengaging.
If you installed an aftermarket clutch the dimensions are likely different from stock. So the measurements and dimensions for the throwout bearing need to change also. Did you measure the travel and operating range of both the new clutch and the throwout bearing? Depending on the parts you are using, you may need to shim the throwout bearing or buy a totally different one altogether. The GT500 throwout bearing is physically shorter than the GT bearing for this reason, for example.
Apologies if you already know and have done this process. Sorry for your frustrations on this and good luck!
Not sure what u mean by low bucking guessing you mean take the cheaper side ? I just can't imagine a rebuilt tranny at 100k miles f d up
N
I asked earlier about hydraulic components being replaced, throw put bearing and master cylinder during previous work. Were they replaced? I assumed they were. If not, that may be your issue. Why would a tech not replace these when they were out?? Going cheap like BS1 mentioned?
So you dont think it could be in the shifter itself ? Or possibly the clutch not disengaging?
With an Exedy Hyper Single clutch, you just swap the 23-spline friction disc for a 26-spline disc. Still may need to re-shim or change throwout bearing, as mentioned above.
So this doesnt have anything to do the reverse lock out pin in the shifter?
Generally, the demise of most mt82s usually start with the gears grinding, historically, that has been a clutch problem, but it almost immediately affects the trans itself, so when you do replace the clutch, you still have issues, or they will become more apparent, The shifter is part of this equation as well, but it seems that it has more of a minor impact, I know guys that have to run mt82s in competition because they have to, they do fine, about half are still running the stock shifter,
So, if you have $10k to dump into this project (or more) there are plenty of alternatives but if you want to fix what you have and be reliable, I think that can be done as well,
If it only locks out of reverse with the engine running the probable cause is the clutch is dragging/not completely disengaging.
A lot of the things you've already fixed could have caused this, but since it keeps reoccurring I suspect the dimensions in your clutch installation. If you've driven it a lot, or continue to drive the car in this condition, it can lead to transmission damage too.
No personal experience but I’ve also heard that if your pilot bearing is worn or frozen, the input shaft can continue to spin even when the clutch is disengaged, potentially causing reverse lockout. It seems logical that this might cause the intermittent lockout you are experiencing. Was the pilot bearing replaced during your clutch job?
Id like to just fix the car and drive it now.
Do you ever experience this in any other gears, or just reverse?
I have a 2013 boss with 128k miles, and I bought it with 113k. The stock shifter and bushings were just completely broken. I replaced the stock shifter with the mgw race spec, and things were a lot better. However, the stock clutch was still having problems, so I replaced it with the exedy hyper twin (organic), along with clutch line, throw out bearing, etc. I really love that clutch. That set up has worked great and my mt82 is still running great.
*However*, almost a year ago, I was doing a brake fluid flush (turkey baster method), and ever since then, I have had occasional issues with my transmission getting stuck in gear. It usually happens as I am slowing to a stop. I can usually "unbind" it if I can get the revs right, but if I can't, I have to shut off the car to get it out of gear. That's a pain in traffic, and not to mention dangerous.
This started literally the day after I flushed my fluid. I think I pulled too much fluid out of the reservoir, and I now have air in the lines. I've tried the brake pedal pump method a few times but it hasn't solved the issue. When I get more free time, I'm going to try to pressurize the system and force the air out, to see if that improves the situation.
I'm not saying your issue is the same as my issue. But I am very familiar with the drivetrain getting stuck and having to shut off the car for the clutch to function correctly. Perhaps your issue is the same root cause. I'd suggest bleeding the entire system one more time before doing something big like changing out the clutch or moving to a new transmission.
Try the inverse. Pull a vacuum on the reservoir using a mityvac or similar to -15 to -20inHg and let it sit for 1 minute. The vacuum will draw the air to the top of the reservoir and it's the official procedure (since techs don't have time to pump the pedal 100+ times in the bay).
That tool is available for about 20 bucks at advanced auto, I use one of those, a rubber stopper with a hole in it ( that is too big to be sucked into the reservoir) and I stuffed a 1/4 inch brass tube pushed through the hole.
You're right - that's what I meant to say. I bought a cheapo hand pump and even a replacement reservoir cap so I can drill it for the tube. If that doesn't resolve the issue, then I'll find a real pump/vacuum solution.
