- 631
- 678
In my experience the drilled out reservoir cap method didn’t hold sufficient vacuum. The drilled out rubber stopper described by @blacksheep-1 worked perfectly. Good luck.You're right - that's what I meant to say. I bought a cheapo hand pump and even a replacement reservoir cap so I can drill it for the tube. If that doesn't resolve the issue, then I'll find a real pump/vacuum solution.
