Torque specs
Discussion in 'Drivetrain, Exhaust and Electrical' started by gripdriver, Feb 1, 2019.
  1. gripdriver
    gripdriver TMO Race
    231
    124
    Jun 27, 2017
    Arizona
    I am preparing to install an Exedy hyper single and I am having a hard time finding torque specs. When I do find specs, they seem to be different depending on where the info comes from.
    Does anyone know what the torque specs for theEH06SD1 Exedy hyper single pressure plate is?
    what about the flywheel bolts? I have found 177in/lbs which converts to 14.7ft/lbs...there is no way that is right.
    any help is greatly appreciated.
  2. byronj
    byronj TMO Addict
    1,382
    326
    Jul 17, 2012
    Bay Area
  3. gripdriver
    gripdriver TMO Race
    231
    124
    Jun 27, 2017
    Arizona
    Thanks but I do not have a 96-04 mustang, and the clutch I purchased is not listed there. That was the first place I tried. I may be missing something on that page you linked though.
    I called Exedy usa and the pressure plate is 23lb/ft with Loctite 242 on the threads. The ARP flywheel bolts are 70lb/ft with Loctite 242 on the threads, and a small dab of assembly grease under the head of the bolt where it meets the surface of the flywheel.
    It is weird to call someone for information in 2019 and get the information in a 2 minute phone call. I have been so used to finding the info I need online for the last 20 years.
    ArizonaBOSS likes this.
  4. byronj
    byronj TMO Addict
    1,382
    326
    Jul 17, 2012
    Bay Area
    You can also refer to ASTM for general TQ specs that's my go to. And when I pulled up that link it was for all years Mustang.
Share This Page
