Thanks a bunch, i'll try that out. By the way, these cars are awesome, totally no regrets!
Orange said:I am not an expert but this is how it works on my 2012:
It takes some time till the Track key is really active, you will see then a sign like engine track key enable or so which comes along with a sound. I believe it has to do that engine etc. needs first some warm up time for safety reasons.
So drive around for a while and at least after 10min. you should get the engine enable sound sign on the dash board and feel the difference and hear also the lopey idle when stopping.
KillerBoss said:New guy here. I just got my brand new 2013 Boss 302 yesterday (4-16-2013). My salesman said the track key had been activated already. How do I know if this is true. My dash says track key active, but it doesn't really sound that different. Like I said i'm knew to the boss community. Can anyone enlighten me, thanks.
Disconnect both battery cables. touch them together.El Jefe 302 said:Hey Justin, How does one do the idle relearn after resetting the PCM? I feel as if you have touched on this before but I can't find the thread and a search just brings me back to this one. Thanks in Advance!
Correct.rpm3dinc said:I was told to reset, just unhook the neg (Black) cable, for 5 min, then reconnect, start car with regular key, let idle for 5 min, and start with track key, done... Is that not correct?
