After a few track days with the Cortex coilover set-up that I purchased from a member here I came to the conclusion that I need to make some changes. The set came with Koni SA up front and JRi DA out back with spring rates of 450F and 225R. I have an 18mm rear bar and 32mm Strano hollow bar up front. I have played with combinations of camber from -3.0 to -5.0, front bar full stiff and middle and front struts full stiff to full soft. My two biggest complaints are front dive under braking that gets the rear very loose and excessive understeer in slower turns.
With the camber at -5.0+ the turn in was amazing as expected but the rear wanted to come around so I had to dial it back. My first thought is I need a much higher rate front spring and/or shock to resist dive. Rear grip was pretty good with the 18mm bar and I am even thinking of going with the 13mm for more bite but that will worsen the front push.
Any suggestions on spring rates? Better shocks? I know there are some very high-end (expensive) remote reservoir shocks that are available but even if I can afford them I doubt I can tune them correctly. Front sway bar size?
Any help would be appreciated. I have all winter to work it out.
Thanks
Thanks
